SMD choke and questions about it
Discussion in 'The Projects Forum' started by jm-a, Mar 27, 2011.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all,
    Need to add , a choke between an igbt module and brushless motor, in order to protect the component.
    On my burnt card, value is really 681 µH , +- 20 % I guess.
    I'd like to know if following items are good for the job:
    http://uk.farnell.com/epcos/b82615b2602m001/choke-ring-core-0-7mh-6a/dp/1644776
    I'm in doubt, i think it's a comon mode choke ....
    Now , about SMD:
    http://uk.farnell.com/wuerth-elektronik/74459268/choke-smd-680uh/dp/1636109
    After a lot of "googling" , I didn't find any information about using and placing it, on a pcb.
    Has anyone any idea or some link to an " how-to" ?
    Thanks a lot.
    jm
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    If it is a choke, its value will be measured in Henries. You could therefore have a 680μH choke, but not 680μF: Farads measure capacitance.
    jm-a likes this.
  3. jm-a
    Oct 20, 2010
    105
    Thanks adjuster, i made a mistake, but yes it's really a choke.
    Thanks a lot.
    jm
