Smartphone HVAC Control
Discussion in 'General Electronics Chat' started by bwilliams60, Aug 6, 2014.
  1. bwilliams60
    Thread Starter Active Member
    Nov 18, 2012
    734
    94
    I have a rather long house and I find my HVAC system is all over the board in terms of individual room temperature and I would like to "balance" my house so it is consistent. I was thinking that ductwork could be controlled using some sort of rotational valve, temperature by individual sensors and airflow the same. I figure this can all be done through a smartphone or tablet. Has anybody here had any experience with this type of system and if so, does it work well and how expensive is it?
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    Why not fix the real problem? Like why your HVAC is all over the place in certain rooms..
    poor insulation? inadequate returns? ,etc...
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    Zonal control with remote will likely cost more than you want to bother with. It's cool, but not so much once you're tired of playing with it.
    If you can identify specific causes for one room going out of control, such as sunlight, closed or inadequate vents or returns, then you're money may be better spent on shades, attic fan or the like.
