Hello my friends,
I've been trying to build a function generator using this schematics from this diy :
http://www.instructables.com/id/OscilloPhone-Use-your-Smartphone-as-an-Oscilloscop/ to observe wave forms and learn about them without buying the expensive ones which i can't afford.
I have some questions and the Author is not responding so any help is appreciated,
Info:
In my design:
1- I dropped the bipoler LED cause I don't have it.
2- I don't have the -+8 volt regulators in my town so I dropped them as well and instead I am using two batteries (about 8v each connected in series with one common, +7.5 and -8)
3- Im not using the entire circuit, I've only built the oscilloscope circuit and used only one op amp of the LM324 just to test it at first
My problems:
1- I noticed that the op amp gets slightly worm when measuring a dc voltage from my ATX power supply using the ocilloscope cicuite inputs, is this normal?
2- when connecting the phone out to the phonr jack and using the app , no wave form is shown??
3- what is the minimum voltage for the circuit to operate?
4-I connected the +voltage to pin4 and -ve to pin11 and common to the common of the circuit in the diagram (Is this right configuration???)
Thanks in advance
The original schematics from the link:
Info:
In my design:
My problems:
Thanks in advance
