smart home system
Discussion in 'Homework Help' started by beauga21, Apr 4, 2009.
  1. beauga21
    Apr 4, 2009
    6
    hello
    am a newbie in logic circuit.
    i was asked to design a simple logic circuit for a smart home home system.
    so i came out with the flowchart i attached with this post.But now am stocked and i don't know how to go from this flowchart to design of the logic circuit using only logic gates.
    if any one have an idea i will be to listen to him..
    thx
  2. mik3
    Feb 4, 2008
    4,846
    63
    Are you sure you have to design this by using only logic gates and not a microcontroller?
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Cannot read the office 2007 Document.
    Can you convert it to PDF, or save any graphics from it as PNG files to attach? There are some online PDF converters avaialble.
  4. beauga21
    Apr 4, 2009
    6
    i have to use logic gates only.
    its a simple one im supposed to design bt i don't have any idea on how to do it.
  5. beauga21
    Apr 4, 2009
    6
    here is the pdf version of the attached document
    thx
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What sensors are you going to use to detect the various on/off states?
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Treat it as if there are magic sensors that give a 1 for on, 0 for off, and the outputs are magic as well. For the stereo, you need two bits, one for on off, second for source (music or voicemail)
    Draw a K-map or Truth table of the inputs and outputs.
    Then transfer k-map to logic (most k-map software will do this automatically).
  8. beauga21
    Apr 4, 2009
    6
    am very newbie to those things could you possible give me an example only for one of the components the lights for example.
    thank you for your help
  9. beauga21
    Apr 4, 2009
    6
    i tried something out to make a circuit for the stereo so i am going to post it and let you see if that's how i should do it.
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's a step. Define the conditions as letters, then use letters for log.
    A=Person In Home
    B=Detected
    C=Stereo System
    C1=Stereo Music
    C2=Stereo Voicemail
    D=Door
    etc. etc. etc.
    Work it all out so every condition has a Yes/No answer (0 or 1 in logic).
    Leave the definitions of variables at the top of the truth table, then show the circuit in gates.
    Hopefully you don't need to build it, 1 function (Input/Output) or IO is a nightmare. So just call the drives and sensors "magic" that profice a 0 or 1 output. As far as detecting different people to count, not quite sure how to do that simply, and most do not want to take a retina scan at the door.
  11. beauga21
    Apr 4, 2009
    6
    am i going to have only one circuit that combine all the components??
