I have been thinking about building a 12v lead acid battery charger and found this schematic floating around and figured I would see what you guys think ???
My problem is that I love electronics and are able to repair many electronics with out any issues but understanding how the circuit works or what does what I have no clue..I have been building a lab a little bit at a time and have alot of stuff but have no idea how to build a simply circuit...I think that would take quite a while to analyze.
At least the IC isn't obsolete.
One always worries, if you have to ask, can you actually assemble this?
Well I was trying to build a smart charger that does everything and desulfating and not kill very expensive batteries for cars ..That circuit looks like it's about 100X as complicated as it needs to be to charge a lead acid battery. FYI, the IC's that have the "BQ" prefix were from a company called Benchmarq. I remember them from the 90's when they first came out claiming they had discovered some way to recharge any battery in five minutes by "sensing" something in the battery to prevent overcharge. It was bogus, they were pretty much discredited. They seem to have made an industry niche creating expensive, complicated IC's for battery charging. Unitrode bought them back in 1998.
I am yet to be convinced desulphating does anything good, at least not the typical chargers sold on the net. Not sure what 'smarts" a lead-acid charger needs. The one I designed has worked really well. I typically get about 6 - 7 years out of my motorcycle batteries.Well I was trying to build a smart charger that does everything and desulfating and not kill very expensive batteries for cars ..
I full agree with Desulphating process...I am yet to be convinced desulphating does anything good, at least not the typical chargers sold on the net. Not sure what 'smarts" a lead-acid charger needs. The one I designed has worked really well. I typically get about 6 - 7 years out of my motorcycle batteries.
How would you go about that??For as complex as that circuit is (I use a simple LM317 circuit), I don't see any allowance for temperature compensation. Next to voltage, temperature is probably the second most parameter, since it affects target voltage.
Temp compensated charger:
Cool I will have to check them out later when more time and thanks for the schematics....3A temp compensated charger with current readouts:
T7 and D8 probably need to be respecified, since these two components are in the power path. So are the shunt resistors R29-31, so you'll need to calculate the new values (ohms and power rating) there as well. Since the shunt will be always "on", choose a power rating at least twice the expected maximum continuous power dissipation. It will last longer.2-Increase charging amp from 1 amp to 3 to 5 amp
