Smallest AC/AC Transformer in the market
Discussion in 'General Electronics Chat' started by Kiken, Jul 3, 2013.
  1. Kiken
    Jun 18, 2013
    7
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    You can make a very small transformer by winding your own on a ferrite bobbin or toroid. If only we knew what are your specifications.
  3. Kiken
    Jun 18, 2013
    7
    Input 220V 50Hz output should ideally be -2.5v to 2.5v, power doesnt matter, i just intent to get this AC Voltaje into a ADC.
  4. crutschow
    Mar 14, 2008
    13,475
    3,361
    You probably wouldn't find anything smaller off-the-shelf for 50Hz than the referenced transformer. Smaller, you could do it yourself as MrChips noted.
  5. #12
    Nov 30, 2010
    16,664
    7,311
    One problem with small transformers is that, for a given input voltage, the smaller it is, the more number of turns of wire are needed. You could get rid of a lot of the voltage with a resistor then wind an isolation transformer as low as 1:1 ratio with only +/- 2.5 volts on the primary. Possibly a tiny audio transformer made for telephone modems? Or wind your own with a lot less number of turns?
  6. Kiken
    Jun 18, 2013
    7
    You say is better for me to make a voltage divider first, then to put a transformer in the mix?
  7. #12
    Nov 30, 2010
    16,664
    7,311
    I told you that a voltage divider would reduce the number of turns that would be required for the transformer to work properly without melting. You decide what is best for you.
