I am looking for a very simple and cheap circuit that will take a small voltage, around 0.6-0.65v and double it. The input may increase, so the circuit should follow accordingly. It will only increase to maybe 1.1-1.3v, so the output would be 2.2-2.6v. Right now I take the source 0.6v and using a 3.3v source and a variable resistor, I bring the 3.3v down to 0.7v and add it to the original source, so if the original source increases, the output does, but its hit and miss sometimes and I would like something to add in between the input and output and not be combining voltages. I'm good at soldering, I've built a few circuit from schematics and such, but just don't understand how everything all works. The minimal component for this, the better, as I'll be making multiple ones for a specific application. Its a very low power, control voltage.
