Small trip computer project but need help with a diagram,very rusty with electronics!
Discussion in 'The Projects Forum' started by t-j-b, Aug 2, 2012.
  1. t-j-b
    Aug 2, 2012
    Hello, I'm new here and looking for advise that could help me with a trip computer project I'm building. My electronics experience is limited, I took GCSE electronics in secondary school many many years ago!
    I'm facing a problem with the wiring diagram that I have, basically I don't understand which components I need to use.
    I have attached a copy of the diagram, and also uploaded it to imgur here http://imgur.com/TnaRb
    Any help would be very much appreciated.
    Thanks, Tom.
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Where is the schematic coming from? Wasn't there a bill of material?
    On the right side you have a few resistors, zener diodes and a transistor. Any of these components you should be able to find in any electronic component store.
    The LCD display is a 16x2 (if the drawing is correct), like this one here: https://www.sparkfun.com/products/255
    EDIT: Just saw that it looks like a automotive device. If that's the case discussion will not be allowed on AAC.
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    What are you trying to accomplish?
    Looks like you have LEFT, MIDDLE, RIGHT buttons to input something, and a big alphanumeric display to show the results. I don't understand what "switched ground injector" or "vss" leads are from or what they are for.
    Guys, it doesn't look like he's modifying the vehicle, he's just powering it inside a car. I am sure he will bring the vehicle to a proper and complete stop before even looking at this thing, no less tapping the buttons.
  4. t-j-b
    Aug 2, 2012
    Its a trip computer that runs from a arduino powered board that can be programmed to read current MPG/Avg MPG ect of a car. Essentially the circuit board/LCD and all other components will be bundled into a box and mounted on the dash. and hooked up to power and a few other essential inputs.
    The switched ground injector and VSS (vehicle speed sensor) are interpreted to provide an MPG reading.
    I was having trouble identifying the components, I can recognise the LCD,resistors and zener diode but not the others.
    Thank you for your help so far, I'm sorry if this type of project isn't allowed in the forum.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    What others? Do you mean the components on the Arduino board? You will not need to identify them. This is all on-board stuff.
