small transformers
Discussion in 'General Electronics Chat' started by Zanac-X, Sep 17, 2012.
Thread Status:
Not open for further replies.
  1. Zanac-X
    Dec 23, 2011
    51
    hey guys :)
    if you open up a mobile battery charger you should see a circuit that has a small transformer in it and i was wundering is that really a small transformer and if it is then why do we use large once.......is it the current that determine the size ?
    and how do you know the ratio and voltage capacity of the coils of the transformer when its small because there is no specifications on them ?
    thanks very much
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    The large transformer you see in a linear power supply serves a particular purpose - to transform high voltage/low current AC at 60Hz to low voltage/high current AC.
    What you see in a battery/lap top charger might not be a transformer.
    It could be an inductor.
    A switching power supply runs at a much higher frequency. Hence the inductance or transformer required is smaller.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    If the charger is a line to low-voltage DC power supply it is indeed a transformer. Otherwise it would not be isolated.
    Ken
  4. Dodgydave
    Jun 22, 2012
    5,154
    772
    Because the small one is a SWITCHED MODE PSU , and doesn't need to be big in size as its "chopping" the mains supply, and not dropping it down like a conventional 50/60Hz transformer.
    Zanac-X likes this.
  5. Sensacell
    Jun 19, 2012
    1,183
    276
    It probably IS a transformer.
    Here is the key- low frequency (mains) = BIG FAT HEAVY power transformer
    High frequency (100's of khz) = SMALL power transformer.
    A switching power supply works by converting the mains voltage into a very high frequency signal that makes efficient use of low inductance small magnetics.
    The transformer works just like a standard mains transformer providing isolation and voltage step-down, only it operates at a high frequency, not 50/60 Hz.
  6. crutschow
    Mar 14, 2008
    13,501
    3,375
    The size of a transformer is determined by its current rating (which affects wire size), its operating voltage, and its frequency of operation. The frequency and voltage determines the required transformer inductance (reactance) required to keep the idle (magnetizing) current at a reasonably small level. For a given reactance, lower frequencies require a higher inductance, thus more turns and a larger core.
  7. szhighstar
    Jun 26, 2012
    27
    5
    I guess it is power inductor, is not transformer.
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    Why??
    Ken
  9. richardlionheart
    Sep 7, 2015
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    Chances are that none of the participants are still interested in responses to a thread that was last active just shy of three years ago.
Thread Status:
