small size diode needed
aruna1
Joined Dec 20, 2008
46
guys I'm looking for general purpose diode like 1N4148.
it should be small.(smaller than 1n4148).
surface mount solution is not going to work as they are very expensive.
I'm working on a circuit and need to use parts small as possible. i use 1/8w resistors and 1n4148 as diodes as they are small.
can you suggest me any diode that has smaller size than 1N4148?
current ratings are not a problem.
thanks
beenthere
Joined Apr 20, 2004
15,819
Here's what you can get -
[SIZE=+1]Dimensions of 2-lead diode packages, as length x width x thickness
[/SIZE][SIZE=+1]or length x diameter (mm)[/SIZE]​
Package Size Manufacturer EMD2 1.2 x 0.8 x 0.6 Rohm PMDT 3.8 x 2.4 x 0.95 Rohm PMDS 4.5 x 2.6 x 2.0 Rohm PMDU 2.6 x 1.6 x 0.8 Rohm TUMD2 1.9 x 1.3 x 0.6 Rohm UMD2 1.7 x 1.25 x 0.7 Rohm VMD2 1.0 x 0.6 x 0.5 Rohm VMN2 0.9 x 0.6 x 0.4 Rohm LLDS 3.4 x 1.5Ø Rohm MELF 4.9 x 2.5Ø
SOD80 3.5 x 1.6Ø
SOD110 2.1 x 1.4 x 1.6
SOD323 2.7 x 1.8 x 1.2
SOD523 1.1 x 0.7 x 0.8
SOD882 1.0 x 0.6 x 0.5
LL34 3.4x 1.5Ø JEDEC
www.practicalcomponents.com/pdf/thruhole.pdf
aruna1
Joined Dec 20, 2008
46
SOD80 3.5 x 1.6Ø
well how to ask for them?
just as only "1N4148" or anyother way?
lightingman
Joined Apr 19, 2007
374
Surface mount 1N4148 diodes can be purchased for as little as 1 British penny each on E-bay. I have bought full reels of them (5000 diodes) for 8 GBP a reel on E-bay.
Good luck.
Daniel.
