Hi all
I need a small size (approx 50mm by 150mm) ADC card with atleast 16 analog channels on it. Each channel sampling rate must be 48 Ksamp/s/ch and ADC resolution must be 16-bit atleast. Further more this ADC card is needed to contineuosly send 16 channel digitized data on 10/100 Mb ethernet real time (without any delay) for further processings. Max Input voltage range is +/- 3 V. In worst case a compromise can be made on sampling rate (min samp rate 15 Ksamp/s/ch)
I search a lot for such ADC card but could not find it. Kindly help me to find a solution
THANKS
THANKS
