Small signal-Hyprid Pi model
Discussion in 'Homework Help' started by u-will-neva-no, May 15, 2011.
  1. u-will-neva-no
    Mar 22, 2011
    230
    Hello again everyone! Basically, I have a common base BJT. I have attached the original schematic and also my small signal representation.
    I have drawn my teachers small signal drawing, which i understand, however I originally thought that the circuit would look like (attachment 3)...I understand that it is wrong because i cannot obtain the voltage gain etc but I thought for the hybrid PI that any components connected to the Emitter of the bjt became connected to the E on the hybrid PI model (like wise for the base and collector).
    So what i would like to know is: why does RS in series with Vin get connected to E on the Hybrid PI model, and also why is RE NOT included in the small signal model in this instance?? Thankyou :)
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Your effort also has Rb connected to the base but in fact this resistance is connected in parallel with a short-circuit, so you should have grounded the base.
    I think the second attachment refers to a "tau small signal model". The base is on the bottom and the emitter is on the left. between them is the internal resistance re and Vbe has inverted polarity.
    Re should be included but if it has a very large value compared to Rs, (which is usually the case) it can be omitted.
    Is that clear?
    u-will-neva-no likes this.
  3. u-will-neva-no
    Mar 22, 2011
    230
    Ahh, brilliant, Thanks Georacer!!
  4. u-will-neva-no
    Mar 22, 2011
    230
    I have one final question, I want to work out the current gain (iout/i in). How would i go about this?
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Place a test voltage source as input. The input current will then be Vin/(Ri+Rs). Find the output current and calculate the ratio Io/Iin.
    All this assumes that you have calculated the DC parameters of the circuit, as well as the input resistance re (Ri).
  6. u-will-neva-no
    Mar 22, 2011
    230
    I would have an equation of tag Iin/Vin = 1/(Ri +Rs) and for the output I think it would be  Iin/Vin = 1/(Ri +Rs)V0/Iout = Rc||Rl.
    Is this formula here correct?
    Basically I want to do  Iin/vin * vin/Iout
    which means I can rearrange my voltage gain formula,which was Vout/Vin = 0.5, leaving me with what is required. This all assumes If the output current formula is correct!
    (also, im trying to use tex tag, sorry if i have messed up...lets find out *sent*)
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    What you want is:
    I_c=a \cdot I_e\ and\\<br />
I_{out}=I_c \frac {R_c}{R_c + R_L}
    Can you figure it out?
  8. u-will-neva-no
    Mar 22, 2011
    230
    But i dont have a value for Vin, other than Vout/0.5 = Vin...
    I dont see how I can make
    Iout = Ic \frac{Rc}{Rc+Rl}
    As a function of Vin so that i can cancel the two when I combine Iin and Iout....
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    You did express the Iin as a function of Vin.
    Now, isn't Iout=Ic*Rc*(Rc+Rl)
    and Ic=a*Ie and Ie IS a function of Vin.
    As a result you can express both Iin and Iout in terms of Vin and it can be removed.
    Can you put it together now?
  10. u-will-neva-no
    Mar 22, 2011
    230
    Ok I think I get it...I can say that IE = Vin/Rs and substitute that into Iout=a*Ie*Rc*(Rc+Rl).
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
    Almost. You had the Ie expression wrong, but you would have the Ai result the same. Let me wrap this up for you:
    <br />
I_{in}=\frac{V{in}}{R_s+R_i}\\<br />
I_{out}=a \cdot I_{in} \cdot \frac{R_c}{R_c + R_l}\\<br />
A_I=\frac{I_{out}}{I_{in}}
    Essentially we see that we don't even need the test voltage source. A test current source is enough for this test, as Iin is directly removed from the Iout expression.
  12. u-will-neva-no
    Mar 22, 2011
    230
    Thank you once again Georacer!!
