Small Signal equivalent circuit
Discussion in 'Homework Help' started by RedX, Nov 20, 2011.
  1. RedX
    Mar 23, 2011
    Image:
    http://www.cramster.com/answers-nov...-circuit-draw-small-signal_1695387.aspx?rec=0
    7) For the circuit given above, draw the small signal equivalent circuit. Include the effect of Early Voltage in your equivalent. Mark each resistor source output clearly. In your equivalent circuit, also show where the base, emitter and collector terminals are.
    Bonus Question:
    8) Using the equivalent circuitry derived above, derive an expression for Rib, the input resistance looking into the base.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Okay, what have you done so far?
