Small project help
Discussion in 'The Projects Forum' started by CalciferC, Dec 12, 2013.
  1. CalciferC
    Dec 12, 2013
    so i wanted to build a small fm transmitter in my home to connect to my pc and transmit through out my house to listen on my fm headphones...
    well i recently came across one of those FM microphones at a garage sale and was wondering, can i just attach a 3.5mm mono-audio plug to the mic wires and plug that into my pc/mp3 player, or would i need to do something else to it first.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Fleabay is full of these things.
  3. wayneh
    Sep 9, 2010
    12,374
    3,226
    Check the range first. I think you'll be lucky if it's more than 10' or so. That may not do you much good.
    In principle you can use an audio signal instead from a PC or mp3 player to replace the mic input to the transmitter but this will require a schematic or a good photo of the PCB for someone with the know-how to make the substitution.
    FWIW, I use a 900MHz headphone transmitter/receiver product that works quite well. The brand is Recoton, I believe.
  4. CalciferC
    Dec 12, 2013
    the range is fine reaches everywhere in my home.
    ill see about making up a schem for it..
