Small portable thermometer, 7-segment display.
Discussion in 'The Projects Forum' started by jsandb, Jan 12, 2014.
  1. jsandb
    Jan 12, 2014
    12
    Hi folks! New here :)
    I'm just starting out and my knowledge of electronics are very limited.
    My idea is to build a couple of small thermometers that i can use for homebrewing. Ranges are from 0 to 100C, but the most important is 50-80C during the mash.
    Is it possible to get better precision than +-0,5C?
    How small is is possible to build a portable thermometer, can i use a smaller battery than 9V that seems to be the most common?
    I've seen some projects using attiny, what do you think of that? Is using an IC the most simple way to build a thermometer?
    My main goals are:
    - As small as possible.
    - Easy to read 7-segment display.
    - Waterproof probe so i can measure temp in liquids.
    - Precise (is under +-0,5C possible?)
    I hope a project like this can be a great learning process.
  2. #12
    Nov 30, 2010
    16,670
    7,314
    The simplest way is to take a $10 bill to the hardware store and buy one. Oddly, you seem to want a learning experience.:confused:
    OK. You have a lot of choices, but "smallest" and "hand made" are not going to happen at the same time. Those Asian factories have hobbyist people completely whipped in the "tiny" department.
    You can make a thermocouple probe. That is really small. A thermistor comes in second, an LM34 comes in third. The digital display will have to be separate from the probe if you want the business end small.
    There's a start. I have to go put the laundry in the dryer now.
    ps, 1/2 C is easy enough. All the retail products can do that.
  3. jsandb
    Jan 12, 2014
    12
    The size is not that important, but ut would be fun if it could be done smaller than using a Arduino.
    Probe-size is not important so the easiest to begin with is the best for me.
    This is mostly for fun and learning so retail is not an option :)
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    Have a look here before you make up your mind.
  5. #12
    Nov 30, 2010
    16,670
    7,314
    Arduino? I'm the local crank on, "Y U put MPU in everything?"
    Look at these datasheets. If you don't want to build the display yourself, you can get the ICL7107 already mounted to a display for $10.50 the last time I bought one. If you're a serious masochist, you can build the ICL7107, one amplifier at a time.
  6. #12
    Nov 30, 2010
    16,670
    7,314
    tracecom had a good idea. $4 for a Harbor Freight meter (if you catch them on sale) and one chip. Same chip I named.
    I hope you are beginning to realize this can be as difficult or as easy as you want it. I remember when we made these out of one transistor at a time and the 8088 was the most advanced chip on the planet.:rolleyes:
  7. jsandb
    Jan 12, 2014
    12
    Looks fun, i'll try that too :)
    That looks great! My plan is to build a few so maybe i can start with the mounted kit and build more stuff myself as my knowledge grows.
    ICL7107 + LM35 feels like a good starting point, maybe a bit too hard but thats better than too easy :)
    You don't happen to remember where you bought ICL7107 + display?
  8. #12
    Nov 30, 2010
    16,670
    7,314
    Yeah, I'll look that up. BRB.
    What country are you in?
    Kind of like this. It's called a panel meter. I'm looking for one with the digital volt meter chip in it.
  9. jsandb
    Jan 12, 2014
    12
    Thanks, i live in Sweden.
    Another thing, what battery do you recommend for this project?
  10. #12
    Nov 30, 2010
    16,670
    7,314
  11. jsandb
    Jan 12, 2014
    12
  12. #12
    Nov 30, 2010
    16,670
    7,314
    You went from, "I don't know" to "That's the plan" in less than 2 hours.
    Not bad for a beginner.:)
  13. jsandb
    Jan 12, 2014
    12
    I'm so eager to get this started!
    I have some time now to read this site and "the art of electronics" until my parts arrive :)
  14. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Look at the DS18S20 or DS18B20. Very easy to interface to with an mcu.
    What is "during the mash"???
    jsandb likes this.
  15. Brownout
    Jan 10, 2012
    2,375
    998
    That's the step that converts grain starch into sugar, which is subsequently fermented into alcohol. Mashing is the hardest part of the process ( as I understand, never did it before ) and anyone who can get consistant results is a brew master.:cool:
  16. #12
    Nov 30, 2010
    16,670
    7,314
    Minor problem..there is no MCU in this design.
  17. THE_RB
    Feb 11, 2008
    5,435
    1,305
    HomeBREWing?
    Alcohol producing yeast are killed in that 50-80'C temperature range.
    However it's an ideal temperature range for home DISTILLING. ;)
    #12 likes this.
  18. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    I made a 6-digit 7seg LCD display some while ago- with 2 controllers.
    Each 3 digit display has serial 3-wire interface.
    The PCB is small, but no so small, after all.
    And it is not totally cheap. A character LCD module would be cheaper.
  19. jsandb
    Jan 12, 2014
    12
    No yeast involved in the mashing process, my fermentation temperature ranges from 18-24'C for ale.
    Neat! Do you some more documentation on that build? :)
  20. takao21203
    Apr 28, 2012
    3,578
    463
    Yes, there will be a new blog entry soon.
    There are two controller chips under the displays (for 7seg decoding/LCD drive)
    For a thermometer, you'd need a 3rd chip on a extra PCB.
    The controllers can use 2v to 5v. PIC32 which I use here is 3 volts only.
    What about i2c temp. sensors? They are small.
    I already have c code to drive the display pcb with a master controller. it is an easy spi-like protocol (serial data transfer).
    jsandb likes this.
