Small motion sensor light?
Discussion in 'The Projects Forum' started by big ragu, Oct 14, 2015.
  1. big ragu
    Sep 3, 2012
    25
    I have a project I'm working on and kind of running into a wall on figuring it out. Historically speaking, I do not have a lot of electronics background so please bear with me. I have a keypad mounted in a housing. This keypad is unlit, making it very difficult for others to see the numbers when it's still dark outside. What I'd like to do is illuminate it with a small light. Possibly LED, or? The other thing I'd like to use is a small motion detector so that it's not lit all the time (not a good neighborhood, not trying to draw attention to it).
    Within the unit I have 24VDC. I also have plenty of room inside to mount a small transformer if needed. I need something that can put up with the elements as it is outside (the light, that is. Any other components would go in the cabinet). Any chance one of you gurus would like to toss some help my way? Thank you
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    Another option would be to just illuminate the keypad for an interval of time once any of the buttons are pressed. The 1st button press is "ignored" as far as the key sequence goes.
    This strategy requires the user to be able to find the keypad, which is easy for a user that knows where it is, and avoids having it light up for just a random passerby.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
  4. big ragu
    Sep 3, 2012
    25
    Thank you for the replies. I need to source the proper light, a simple LED won't provide enough light. After looking at the link you provided, the motion detection side will be simple.
  5. mcgyvr
    Oct 15, 2009
    4,787
    973
    For simple keypad illumination? Sure it will..
    you can put a few in series if you need a bit more.. but a 20mA white LED should be more than sufficient for keypad illumination IMO..
  6. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Have you seen how bright LEDs are these days?
  7. big ragu
    Sep 3, 2012
    25
    Apparently, I stand corrected! Like I said before guys, I'm not doing this kind of stuff often so I'm not all that knowledgeable. So it looks like I can get a PIR sensor, 1 or a couple of LED's, and whatever resistor I'll need and be all set? I have 24vdc in the keypad, I'll have to knock it down to 9 or so. Any idea how long a 9v. battery would last roughly if I went the battery route?
  8. mcgyvr
    Oct 15, 2009
    4,787
    973
    avoid batteries if you have a power source already.. Add a 12V regulator circuit off your 24VDC supply and call it a day.. No worries about replacing batteries.
