Small memory sizes
Discussion in 'General Electronics Chat' started by Robin Mitchell, Jul 31, 2011.
  1. Robin Mitchell
    Oct 25, 2009
    738
    206
    Hi everyone,
    Are there any chips widely available that have very small memory (parallel not serial) sizes like 256 bytes? (I mainly need small pin packages)
    Many thanks
    Robin
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    How about the 2114?
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    You can use 28xx chip EEPROM .............
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    The 2114 - that takes me back! The power consumption is quoted at 1W. At that rate, the memory in the computer in front of me would be running to several kW.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I still have some HM6116 and HY6264 memory chips laying around.
    Bertus
  6. Kermit2
    Feb 5, 2010
    3,846
    963
  7. ErnieM
    Apr 24, 2011
    7,435
    1,625
    RAM? ROM? EPROM? EEPROM? FLASH? STATIC? DYNAMIC?
    PARALLEL? SERIAL? I2C? SPI?
    AM or FM or PM too.
    Churnin' out that boogaloo
    Gets you up and gets you out
    But how long can you keep it up?
    Gimme Honda, gimme Sony
    So cheap and real phony
    Hong Kong dollars, Indian cents
    English pounds and Eskimo pence
  8. Robin Mitchell
    Oct 25, 2009
    738
    206
    EEPROM, FLASHH and STATIC
    Parallel only
  9. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I poked around Digi Key's memory section, it seems you may have to go a little larger (1Kx8) to find anything still in production
  10. praondevou
    Jul 9, 2011
    2,936
    489
  11. praondevou
    Jul 9, 2011
    2,936
    489
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Who is behind this??
