Small Internet Info Push Hardware
Discussion in 'Embedded Systems and Microcontrollers' started by Justinwiz, Apr 13, 2010.
  1. Justinwiz
    Apr 13, 2010
    What would be the best way to receive information from a serial port (or USB serial connecter) and then post the data to the web (GET/POST) for an affordable price?
    I'm trying to make a power meter that reads the pulses from the LED on the front panel of the power meter.
    I have a Picaxe-08M with LDR and a serial connector made and working, it outputs the number "1" on to the serial port every time the LED on the panel pulses. My problem is: I don't want to have a normal server running only to do that, and wasting power (defeating the purpose)...
    Any ideas? Maybe Windows CE?
    Thanks :D
    - Justin (Newcomer)
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    An XPort might work, not expensive either.
    Justinwiz likes this.
  3. Justinwiz
    Apr 13, 2010
    Thanks!
    I'll look into that :)
  4. retched
    Dec 5, 2009
    5,201
    313
    You may want to check ladyada's website. She has done just that. Her Kill-a-watt reports to her pc which then updates her website so she can monitor her kill-a-watt readings from the internet.
    Pretty much exactly what you want to do.
    http://ladyada.net/make/tweetawatt/index.html
    She reports to twitter for distribution, but she uses a back end first, that you can have your info posted anywhere.
