Small electric motor for slow spinning disk
Discussion in 'General Electronics Chat' started by Lance Corlett, Feb 8, 2016.
  1. Lance Corlett
    Feb 8, 2016
    Hi everyone,
    I am an artist which knows absolutely nothing about the electrical world, and I am trying to create 2 small slow spinning disks which sit behind my artwok.
    Ive attached a pictures of my attempt and also the gearbox Ive used - This panel attaches to the back of my artwork - 2 x electric motor powering a lowest ratio gearbox which I attach my spinning panel to. (one attached, one is not)
    To my surprise I actually got it to work however it is extremely noisy and does not spin slow enough. Is there another way to achieve this where I could even control the speed?
    Thanks in advance,
    Lance
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    A simple way is to just lower the supply voltage to the required rpm.
    e.g, if it is a 6v motor try 3v, you could test this with batteries first if mains powered supply.
    Max.
    Lance Corlett likes this.
  3. Alec_t
    Sep 17, 2013
    5,980
    1,138
    How slow is slow?
    The turntable motor from a microwave oven does about 20rpm and is almost silent. However, it needs mains power, not a battery supply.
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    You may be able to reduce the noise by putting some sheet rubber or other isolation between the motor and the plywood to reduce the vibrations transferred from the motor to the plywood.
  5. Lance Corlett
    Feb 8, 2016
    Thanks guys all very helpful. I think I will try halving the voltage and putting some rubber slips in. If that fails I will probably just try find someone who knows what they are doing and pay them
  6. wayneh
    Sep 9, 2010
    12,402
    3,249
    What rpm do you need? A belt drive with a high ratio would be much quieter than a plastic gearbox. That's how a typical turntable used to work.
  7. Sensacell
    Jun 19, 2012
    1,184
    277
    Rubber mount the motors- and note that gear noise can come from the shaft itself.
    You might want to rubber isolate the disk from the motor shaft too.
    DC gear motors tend to be noisy, but that's where you are when it needs to run on battery power.
