Small Diode Emitter Resistance,RE
Discussion in 'General Electronics Chat' started by seikoemill89, Sep 21, 2011.
  1. seikoemill89
    Sep 21, 2011
    hi everyone,here i would like to ask on how to prove this below equation
    IE=Is(qVBE/e kT -1) until we get this equation:re=26mV/IE..
    this is from the topic of BJT Biasing...hopefully someone can help me to solve this...TQ
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    For a diode with voltage drop Vd & current Id.
    By Shockley's equation
    I_d=I_s(e^{\frac{\normalsize{q} V_d}{kT}}-1)
    (e^{\frac{\normalsize{q} V_d}{kT}}-1)=\frac{I_d}{I_s}
    e^{\frac{\normalsize{q} V_d}{kT}}=\frac{I_d}{I_s}+1
    Taking the natural logarithm of both sides gives
    \frac{\normalsize{q} V_d}{kT}=ln(\frac{I_d}{I_s}+1)
    V_d=\frac{kT}{\normalsize{q}}ln(\frac{I_d}{I_s}+1)
    Differentiating wrt Id gives
    \frac{d(V_d)}{dI_d}=\frac{kT}{\normalsize{q}} \frac{\frac{1}{\normalsize{I_s}}}{(\frac{ \normalsize {I_d}}{ \normalsize {I_s}}+1)}
    \frac{d(V_d)}{dI_d}=\frac{kT}{\normalsize{q}}\frac{1}{\normalsize{I_d}+\normalsize{I_s}}
    Normally Id>>Is
    So to a good approximation
    \frac{d(V_d)}{dI_d}=\frac{\frac{kT}{\normalsize{q}}}{\normalsize{I_d}}
    typically at room temp
    \frac{kT}{\normalsize{q}}=0.026 \ volt
    and
    \frac{d(V_d)}{dI_d}=\frac{0.026}{\normalsize{I_d}}
    If the term
    \frac{d(V_d)}{dI_d}
    is recognized as effectively a small signal dynamic resistance rd
    then
    r_d=\frac{0.026}{\normalsize{I_d}} \ ohms
    For the BJT emitter region diode junction we can state (by a similar process) the equivalent dynamic emitter resistance for a quiescent emitter current IE
    r_e=\frac{0.026}{\normalsize{I_E}} \ ohms
    Or if IE is expressed in mA
    r_e=\frac{26}{\normalsize{I_E[mA]}} \ ohms
    anhnha likes this.
  3. seikoemill89
    Sep 21, 2011
    thank you so much for t_n_k...the answer is so meaningful for me because i am a fresh degree student,so i have forgotten what i have study before in diploma...a lot of thanks for you...peace!
