Yes..Is there any advantage to using more capacitance? The more the better? Or one will work just fine?mF is millifarads. If I'm not mistaken, you had 2.2mF caps on each of your power supply rails in one of your schematics.
Also, If/when I add biasing diodes to reduce crossover distortion do I add them the same as the dual rail power supply amp? From base to base, and a resistor from VCC? I have seen capacitors across the base over to the emitter on the original circuit I went off of, should I add one? And last, there is another cap...look here http://www.allaboutcircuits.com/vol_6/chpt_6/10.html Should I add in those other components?
