patricktoday
- Joined Feb 12, 2013
- 157
Are you still referring to the original circuit you posted in post #1? Here's an article which ends up with a very similar circuit arrangement and provides some analysis on using negative feedback from a class B output stage back to an op amp:
http://www.allaboutcircuits.com/vol_6/chpt_6/10.html
As far as your "middle stage," since your op amp is directly driving the output transistors (currently) and their gain is low, doing a darlington configuration for each output transistor would be one technique to reduce the op amp's current load.
