As much as I enjoy good old-fashioned, classical English, its American counterpart has its beauty too:My fave is "The Poison Belt":
" Our Gardener is, in my opinion, about to dip the solar system, and the human bacillus, the little mortal vibrio which twisted and wriggled upon the outer rind of the earth, will in an instant be sterilized out of existence..."
Great stuff!...
Best regards
HP
I do not have a feel for poetry but my suggestion anyway: try Whitman one of these days.As much as I enjoy good old-fashioned, classical English, its American counterpart has its beauty too:
"And all my days are trances, and all my nightly dreams, are where thy dark eye glances, and where thy footstep gleams, in what ethereal dances... by what eternal streams"
E.A. Poe
I hope you're joking? If the OP tries that the fan will die due to coil saturation.FWIW I'd just use a diode...
Hence my amendment in the post script...I hope you're joking? If the OP tries that the fan will die due to coil saturation.
Sounds like a plan!Woow, Guys. You are amazing!
Thank you for all the inputs, hehe...
Since there was also no objections to using a light bulb, I will test it right now before and after the switch..
I've used phase angle control circuits in small single phase ac induction motors in the past with no problem. Specifically for a sump pump... but maybe the TS is looking for a much simpler solution...If the fan has a simple induction motor, adding resistance just reduces the current and the torque.
The fan's air resistance applies a counter torque on the motor so the fan speed will decrease until the motor and fan torque reach equilibrium. However if the frequency remains at 60 Hz. while the RPM decreases, the "slip" of the induction motor will increase. I get a sneaking feeling that there's a "Rat In The Woodpile" and something's going wrong somewhere.
Indeed, symmetrical phase control, although expedient, may briefly function satisfactorily on low power induction motors -- That said, inasmuch as the upshot is merely reduction of mean power to the motor, the considerations/concerns rased in post #48 apply!I've used phase angle control circuits in small single phase ac induction motors in the past with no problem. Specifically for a sump pump... but maybe the TS is looking for a much simpler solution...
So now we've evolved from a simple resistor to a diode to an inductor to phase angle control to an inverter... and nothing seems to be 100% adequate to control the speed of a simple fanJust as word of caution, using an inverter to control fan speed may cause problems with the motor winding's insulation.
Most inverters use IGBTs which have very sharp rise and fall characteristics and they contain harmonics in the RF range. These harmonics can puncture the insulation of a conventional line operated motor.
Before connecting it to an inverter, the motor should have a label that says something to the effect that it is "Inverter Compatible".
Agreed! --- That said, I feel the OP's best (i.e. most practical) solution is purchase of a multi-speed fan...If you want "infinite resolution" for speed control of an induction motor, the only theoretically correct solution is to use an inverter.
That'll probably be cheaper than an inverter!Agreed! --- That said, I feel the OP's best (i.e. most practical) solution is purchase of a multi-speed fan...
Best regards
HP
Definitely, and it actually is a multi speed fan, the problem is, that I sit 1m bellow it, and all four speeds are way to fast. I tried with another cheap ebay FAN multi switch, and the speeds were the same. And for 3 bucks I got also ton of extra HUM.Agreed! --- That said, I feel the OP's best (i.e. most practical) solution is purchase of a multi-speed fan...
Best regards
HP
No worries Bud, only diodes i used so far in my projects are those shiny LED ones, so no worries there. TY!Sounds like a plan!
Whatever you do --- Please DO NOT take my STUPID advice (in post #10) in regards to use of a diode as a '∏θ phase control'! --- Doing so would certainly result in overheating with subsequent damage and, possibly, fire! -- Sorry about that! - Seems my brain wasn't 'set' for 'induction motor'
Contritely
HP
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Aaron Carman
