slow voltage fade circuit
Discussion in 'The Projects Forum' started by lefevrej, Apr 16, 2009.
  1. lefevrej
    Apr 16, 2009
    Hello- I need to create a circuit which provides a slow voltage reduction over time. This is an application which simulates a sensing device, so is very low power application. Specifically, I have a 5V DC reference voltage which I need create an output from 4.5V to 0.5V over a period of 3 hours or so. I would like to include a pot of some sort to vary the rate of decay. Could someone get me pointed in the right direction?
    jl
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We used to do something like that for testing chart recorders. The circuit applied a slow clock to a couple of counter IC's that fed a D to A converter. Your app can reset the counters to maximum and count down at the correct rate for the 3 hour period.
  3. lefevrej
    Apr 16, 2009
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
