hi, i'm fairly new to this, so please forgive me with anything i'm doing wrong.
i'm working on a school project. i'm designing a digital slot machine on multisim12.
for the slot machine, i'm using a 0-9 up counter designed with 4 JK flipflops. (3 counters all in all)
the outputs of each flip flop are fed into the input of a BCD to 7-segment decoder then to a 7 segment display.
i wanted my pay out to be the following:
numbers that are not equal = $0
000 - 666 = $20
777 = $999
888 and 999 = $200
however, i am having problems comparing the 3 numbers. right now, i am using nand gates to compare the BCDs of each displayed digit, then the outputs of the nand gates are the inputs of a 2 input nor gate with the other connected to ground. the outputs of the nor gate are then the A inputs of a 4 bit magnitude comparator with the B inputs set at 0111.
it works at 777, however regardless of whether the numbers are 1-1-1 or 1-2-3, the A less than B output is always $20.
000 - 666 = $20
777 = $999
888 and 999 = $200
