sliding door
Discussion in 'General Electronics Chat' started by Kaiser Ed Bayawa, Feb 7, 2016.
  1. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    hi.. I am making a simple automatic sliding door with an LDR sensor and a triac to drive the motor.
    the problem is when the door is open i dont have an idea to close it. what will i do to reverse the polarity of the motor?
  2. ISB123
    May 21, 2014
    1,240
    531
    You need H bridge.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    What kind of motor do you use?
    Also keep in mind that you block the movement of the door when there is something in the doorway.
    Bertus
  4. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    What is an h bridge sir
  5. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    I am using a servo motor
  6. djsfantasi
    Apr 11, 2010
    2,905
    878
    How are you driving the servo motor to open the door? Servos operate differently than DC motors.
  7. ISB123
    May 21, 2014
    1,240
    531
    Kaiser Ed Bayawa likes this.
  8. djsfantasi
    Apr 11, 2010
    2,905
    878
    But not a servo.
  9. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    I have also here a dc motor sir. Which on I will use
  10. ISB123
    May 21, 2014
    1,240
    531
    Didn't see he was using a servo. Servo is driven with PWM, NE555 can be used.
  11. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    Thank you for the help sir. I will do a research about this h bridge and how to use it.
  12. MaxHeadRoom
    Jul 18, 2013
    10,846
    2,521
    You can also drive a servo motor with plain DC which is reversed by contactor or relay.
    PWM is if you require rpm control.
    This is assuming it is not a simple RC servo but an industrial one?
    Max.
  13. twohats
    Oct 28, 2015
    10
  14. MaxHeadRoom
    Jul 18, 2013
    10,846
    2,521
    It sounds like you are powering it already to open it, you just need reversal?
    It is wise to qualify in your OP whether it is a model RC servo type or other.
    Max.
    djsfantasi likes this.
  15. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    Can I combine this scr circuit with the h bridge sir ? instead of using the lamp in the scr I will change it with the h bridge together with the motor
  16. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    Is it possible to combine the two circuit sir and how?
