Slide Potentiometer
Discussion in 'General Electronics Chat' started by RdAdr, Aug 7, 2016.
  1. RdAdr
    May 19, 2013
    214
    I have a slide
    potentiometer and I used it on a voltage divider.
    So I slide and the voltage changes from 0 to 5V, maybe.
    Then I feed this voltage into the Arduino's ADC and I see that, even though the cursor is in some fixed position, the voltage varies a little. Thus the ADC outputs: 345, 346, 360, 344, 340, etc. So it does not output some fixed value like 345, but it kinda varies around this value.
    So the voltage is not stable in the mV range. It is stable in the V range because if I measure with the multimeter I see 1.4V, for example, and not 1.4,1.5,1.3,1.4 etc. But always 1.4V.
    My question. How do I stabilize the output voltage so that it stays fixed in the mV range too?
    Obs: The supply voltage that feds the voltage divider comes from arduino and its very stable: 1023 always.
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    How stable is the input voltage to the voltage divider?
    You can also try to add a capacitor on the output of the voltage divider.
    You can also average some values in the Arduino.
    Bertus
  3. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi Rd,
    The ADC measurement is ratiometric, so when measuring the MCU supply voltage it will always read 1023.
    So its not a 'reliable' reference.
    E
  4. RdAdr
    May 19, 2013
    214
    The input voltage to the voltage divider is the VCC of the Arduino and it is very stable. It stays always at 1023 if I read it on the ADC.
    The two solutions seem good enough. I will see if I can make them work with the rest of my code. The output voltage of the divider is used as a variable reference for a closed loop control system.
  5. RdAdr
    May 19, 2013
    214
    Oh
  6. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi Rd,
    Also if your test potentiometer is a carbon track type, they can be 'noisy'
    E
  7. RdAdr
    May 19, 2013
    214
    I just used another reference coming from two 1.5 batteries in series and I see it is more stable. So the Arduino supply was the cause, not the potentiometer itself.
    Although I still see some little varying. When the output voltage is minimum, i see : 104,107,105,103,108... which is better, but occasionally a value around 96 appears.
    I think with a capacitor this will be solved even further maybe.
  8. RdAdr
    May 19, 2013
    214
    I do not know the material.
    I mean, it's carbon.
    What material is less noisy?
  9. Alec_t
    Sep 17, 2013
    5,976
    1,136
    The wires from the pot to the Arduino act as antennae and pick up interference, which can affect the measurement unless suppressed by use of a cap as suggested above.
  10. ci139
    Member
    Jul 11, 2016
    341
    39
      File size:
      33.7 KB
  11. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi Rd,
    Connect a 1K resistor in series with the pot slider output and the ADC input, connect a 10nF cap from the ADC input to 0V
    E
  12. RdAdr
    May 19, 2013
    214
    Ok, thanks. I will buy some capacitors and see what happens.
  13. RdAdr
    May 19, 2013
    214
    Isn't too small though? I was thinking more in the uF range.
  14. ericgibbs
    Jan 29, 2010
    2,595
    393
    The size of the capacitor will depend upon your application.
    ie: if you want to measure slowly changing voltages then a higher cap value would be OK.
    If you used a high value on rapidly changing input voltages, the readings could be incorrect.
    What is your actual application.?
    E
    EDIT:
    what is the resistive value of your potentiometer.?
  15. RdAdr
    May 19, 2013
    214
    The ADC measures once every 100 microseconds.
    The potentiometer is in the image.
    I guess 10nF seems ok.
      File size:
      4.9 KB
  16. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi.
    Your diagram looks wrong.?
    Where does the pot slider go.?
    E
    BTW: a 50k pot is too high a resistance, the MCU's ADC input usually expect an input resistance of 10K or less
  17. RdAdr
    May 19, 2013
    214
    The pot slider is changed by my hand.
    The OUT pin goes into the ADC. And the input resistance is below 10000 (if I remember thevenin's method correctly)
  18. ericgibbs
    Jan 29, 2010
    2,595
    393
    As you are changing the ADC input slowly by hand, a 100nF on the ADC input to 0v will be OK.
    Are you always going to be changing the input by hand.?
  19. RdAdr
    May 19, 2013
    214
    Yes, only by hand. But I can't say that I will change it slowly or fast. My problem was that once changed to some position, the output voltage still varies due to noise or the supply voltage
    And I think that when i change by hand and it goes suddenly from 1V to 3V, then the capacitor will have some delay, but if this delay is not really noticeable by eye, I wont care too much
  20. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    According to your schematic, the voltage can vary between Vcc/6 and Vcc.
    As said, the MCU will load the voltage divider quit a bit.
    You could use a voltage follower between the voltage divider and the MCU input to aviod this.
    Bertus
