Slew Rate Distortion
Discussion in 'Homework Help' started by Schmitt_trigger, Feb 6, 2013.
  1. Schmitt_trigger
    Feb 5, 2013
    20
    I have another problem that states:
    Determine the maximum frequency without distortion that we can get at the output of an ampop with SR=1V/microSecond
    a)If the input is a sinuosoid function with 5 V of amplitude
    b)If the input is a triangular wave with 5 V of amplitude
    <br />
<br />
a) <br />
<br />
W*Vmax=SR<br />
<br />
2*pi*fmax=SR<br />
<br />
fmax=(SR)/(2*pi*Vomax)<br />
<br />
fmax=31830,98 HZ<br />
    What would be the difference in the calculations if we have a input that is a triangular wave?
  2. crutschow
    Mar 14, 2008
    13,509
    3,385
    With a sinewave you need to differentiate the sinewave to find the maximum slew-rate point since the waveform slew-rate is not a constant. This gives the 2*pi*fmax function.
    A triangular wave has a constant slew rate so you don't have to differentiate the signal to find the maximum. It's simply the pp voltage divided by the time for the waveform to go from the minimum to the maximum voltage.
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
    The problem doesn't provide enough information since the slew rate applies to the output voltage and all that is given is the input waveforms. You also need to know the gain of the circuit.
  4. Schmitt_trigger
    Feb 5, 2013
    20
    So my input signal is  Vi=5*sin*(1*10^6t) which differenting gives:10000000 *pi* cos(2000000* pi* t) so the maximum will be 10000000 *pi at  t=n/1000000
    How do i know if i have distortion?
  5. WBahn
    Mar 31, 2012
    18,089
    4,917
    Would the output have to be able to change faster than it is rated in order to keep up with the signal? But don't forget that it is the OUTPUT signal that matters.
  6. Schmitt_trigger
    Feb 5, 2013
    20
    The problem is that i only know the input signal.I know the maximum variation of the input signal but i do not know what is the ouput for that input..
  7. WBahn
    Mar 31, 2012
    18,089
    4,917
    Then just assume a gain of K and write your result in terms of K.
  8. Schmitt_trigger
    Feb 5, 2013
    20
    So i assume a certain k the multiple it by my input signal.Then calculating the derivative of my ouput signal e check is the value is bigger than the slew rate,rigth?
  9. WBahn
    Mar 31, 2012
    18,089
    4,917
    Yes, but remember that you have to check the maximum value of the derivative.
