It's possible. A bigger danger is overshoot that might be higher than the voltage rating of connected components. If you have long connecting lines, that danger is greater.default setting is it is turned off, so if you don't do anything it will still be at it's maximum slew rate. Did you suspect that it can affect other devices through EMI?
Thanks hgmjr
Thread starter | Similar threads | Forum | Replies | Date |
How to measure slew rate of Op-Amp Practically ? | Test & Measurement | 14 | ||
S | Slew rate Max frequency | Analog & Mixed-Signal Design | 10 | |
M | Slew Rate/Rise Time Conversion | Digital Design | 4 | |
M | Rise time vs Slew Rate - Trying to see if this circuit will work | Digital Design | 2 | |
N | Slew rate control | General Electronics Chat | 19 |
by Jake Hertz
by Jake Hertz
by Jeff Child
