Slave I2C interrupt latency?
Discussion in 'Embedded Systems and Microcontrollers' started by dtrott, Sep 30, 2011.
  1. dtrott
    Sep 29, 2011
    Hi all,
    Here is an unusual one, maybe someone brighter than me can help.
    I have a pic18f4550 as a USB device and a master to a pic16f88 acting as a slave that will be doing analogue sampling. At the moment, all the master is doing is repeating a write of one bight. After many hours not having luck trying to debug both, I hooked the master up to an eeprom just to get that one sorted from an I2C standpoint. No problems, too easy.
    I did find that I hadn't set my baud rate correctly, it was at about 225kHz but now fixed that and its at 100kHz (verified with scope) and pins tied high with 2k2 resistors.
    After i fixed that, the slave worked - kind of.
    I have the master turning on a green light when an ack is received and a red light when a nack is received (easier to see than getting the scope triggering properly). With the master running by itself and the slave in debug with an ICD2 through MPLAB, I couldn't get any acks when running the program right after a chip burn. However, after a reset, I could, but then only acks for a second maybe (and some times more, sometime less).
    So after some more hours of debugging I thought I had it. It was acking continuously. So I thought I'd clean up my code and get rid of all the temporary variables that I was using to find faults.
    This is where it got strange. After I deleted one temporary variable in the isr (which did a second bitmask on the SSPSTATUS register, checking for a stop bit ) I could only get an ack for a second again. In the code below you'll see in the interrupt routine that there are 4 NOP instructions. One more than that, < 1 second of acking, one less than that, < 1 second of acking, 4 - continuous acking.
    Anyone with ideas? Why is 4 nop's the magic number?
    By the way, using Hi-Tech for the slave and C18 for the master.
    Slave code:
    Code ( (Unknown Language)):
    1.
    2.
    3. #include <htc.h>
    4. #define true 1
    5. #define BYTES 64
    6. /***** Global Variable ********/
    7. void delay(int);
    8. void init(void);
    9. void i2c_init(void);
    10. void i2c_start(void);
    11. void i2c_write(char);
    12. void i2c_stop(void);
    13. void i2c_wait(void);
    14.
    15. void i2c_init(void)
    16. {
    17.  SSPEN      = 1;   //Enables Serial Port Mode
    18.  INTCONbits.PEIE = 1;
    19.  SSPCONbits.CKP =1; //Clock Released
    20.  SSPBUF = 0 ;
    21.
    22.  /* SSPCON REGISTERS */
    23.  SSPCONbits.SSPM = 0x6;
    24.
    25.  /* SSPSTAT REGISTERS */
    26.  TRISB4 = 1;  // SCL as input
    27.  SMP = 0;   //Slew Rate Control Disabled
    28.  CKE   = 0;   //SMBus Specific Inputs Disabled
    29.  SSPADD = 0xAE;
    30. }
    31. void delay(int pause)
    32. {
    33.    unsigned int i, j, k;
    34.
    35.    unsigned int clock = 6;
    36.    unsigned int cycle = 14;
    37.
    38.    for(i = 0; i <= pause; i++){
    39.    for(j = 0; j <= clock; j++){
    40.    for(k = 0; k <= cycle; k++){
    41.       asm("nop");
    42.    }}}
    43. }
    44. void Initialise()
    45. {
    46.  SSPSTAT = 0;
    47.
    48.  ANSEL = 0b1111;  // Select Channel 0 through to 3 as analogue inputs
    49.  TRISA0 = 1;  // RA0 as input
    50.  TRISA1 = 1;  // RA1 as input
    51.  TRISA2 = 1;  // RA2 as input
    52.  TRISA3 = 1;  // RA3 as input
    53.  TRISB1 = 1;  // SDA as input
    54.
    55.  ADCON0 = 0b11000001;
    56.  ADCON1 = 0b10000000;
    57.  INTCONbits.PEIE = 1;
    58.  PIE1bits.SSPIE = 1;
    59.  GIE = 1;
    60.
    61.  TMR0IF=0;
    62.  T0CS=0;
    63.  TMR0IE=0;
    64.
    65.  TMR0 = 0x00;
    66.
    67.  OPTION_REG = 0b11001000;
    68. }
    69. void main(void)
    70. {
    71.  Initialise();
    72.  i2c_init();
    73.  while (true)
    74.  {
    75.   i2c_wait();
    76.  }
    77. }
    78. void i2c_write(char byte)
    79. {
    80.    SSPBUF = byte;
    81.    i2c_wait();
    82. }
    83. void i2c_wait(void)
    84. {
    85.    while ( SSPIF==0 );
    86.    SSPIF = 0;
    87. }
    88. void interrupt isr(void)
    89. {
    90.  unsigned char CASE_SWITCH;
    91.  unsigned char temp;
    92.  unsigned char dataToMaster;
    93.  if (PIR1bits.SSPIF == 1)
    94.  {
    95.   PIR1bits.SSPIF = 0; // reset SSP interrupt flag
    96.   CASE_SWITCH = SSPSTAT & 0x2D;
    97.   asm("nop");
    98.   asm("nop");
    99.   asm("nop");
    100.   asm("nop");
    101.
    102.   switch(CASE_SWITCH)
    103.   {
    104.    case 0x09 : // master write last byte was addr
    105.    {
    106.     if(SSPCONbits.SSPOV == 0)
    107.     {
    108.      SSPCONbits.CKP = 0;
    109.      temp = SSPBUF; // just dummy value to clear
    110.      SSPCONbits.CKP = 1;
    111.      break;
    112.     }
    113.    }
    114.
    115.    case 0x29: // master write last byte was data
    116.    {
    117.     if(SSPCONbits.SSPOV == 0)
    118.     {
    119.      SSPCONbits.CKP = 0;
    120.      readValue = SSPBUF; // just dummy value to clear
    121.      SSPCONbits.CKP = 1;
    122.      break;
    123.     }
    124.    }
    125.
    126.    case 0x0c: // master read last byte was addr
    127.    {
    128.     temp = SSPBUF; // just dummy value to clear
    129.     SSPCONbits.CKP = 0;
    130.     SSPBUF = dataToMaster;
    131.     SSPCONbits.CKP = 1;
    132.     break;
    133.    }
    134.
    135.    case 0x2c: // master read last byte was data
    136.    {
    137.      temp = SSPBUF; // just dummy value to clear
    138.     SSPCONbits.CKP = 0;
    139.     SSPBUF = dataToMaster;
    140.     SSPCONbits.CKP = 1;
    141.     break;
    142.    }
    143.
    144.    case 0x28:  // S = 1, R_W = 0, D_A = 1, BF = 0
    145.    {
    146.     temp = SSPBUF; // just dummy value to clear
    147.     // Master NACK
    148.    break;
    149.    }
    150.
    151.    default:
    152.    break;
    153.   }
    154.  }
    155. }
    156.
    157.
    Here is part of the master code, there is a load of USB code that i didn't include as part of this. This function gets called by a flag in the main function, set on a timer interrupt.
    In main() is:
    1.
    2. writeByteI2C(rw, 0xAE, 0x78 );
    3.
    the function on the master is:
    1.
    2. unsigned char writeByteI2C(  unsigned char rw,  unsigned char add,  unsigned char data )
    3. {
    4.  unsigned char result = -1;
    5.
    6.  if (rw == 0)
    7.  {
    8.   add = 0xFE & add;
    9.  }
    10.  else
    11.  {
    12.   add = 0x01 | add;
    13.  }
    14.  IdleI2C();                          // ensure module is idle
    15.  StartI2C();                         // initiate START condition
    16.  while ( SSPCON2bits.SEN );          // wait until start condition is over
    17.  //WriteI2C( ControlByte );          // write 1 byte - R/W bit should be 0
    18.  IdleI2C();                          // ensure module is idle
    19.  result = WriteI2C( add  );          // write address
    20.  IdleI2C();                          // ensure module is idle
    21.  if (result == 0)
    22.  {
    23.   PORTAbits.RA4 = 1;
    24.   PORTAbits.RA5 = 0;
    25.   result = WriteI2C ( data );     // Write data byte
    26.   if (result == 0)
    27.   {
    28.    PORTAbits.RA4 = 1;
    29.    PORTAbits.RA5 = 0;
    30.   }
    31.   else
    32.   {
    33.    PORTAbits.RA4 = 0;
    34.    PORTAbits.RA5 = 1;
    35.   }
    36.  }
    37.  else
    38.  {
    39.   PORTAbits.RA4 = 0;
    40.   PORTAbits.RA5 = 1;
    41.  }
    42.  IdleI2C();                          // ensure module is idle
    43.  StopI2C();                          // send STOP condition
    44.  while ( SSPCON2bits.PEN );          // wait until stop condition is over
    45.  return ( 0 );                       // return with no error
    46. }
    47.
    48.
    I have spent hours looking over forums and there are others with similar problems but nothing has seemed to work, maybe if someone could offer a solution to this it may also help others starting out in I2C between two PICs.
    Thanks for reading,
    Dan.
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    I feel your pain. More like I felt it a few years back when I did a PIC slave device. While I got it to work I don't remember any particulars, except the official documentation was filled with errors.
    FWIW here's my source, done for a p18f4550 on the C18 compiler. I'm not sure this still compiles in the current C18 compiler.
    I believe state 2 is so long and convoluted to convert a "data address" to pointers to where I stored variables so I could read each one out.
    1. void SSPIF_Vector()
    2. {
    3.   _asm
    4.   GOTO SSPIF_Handler
    5.   _endasm
    6. }
    7.
    8. //#pragma code
    9. //#pragma interrupt SSPIF_Handler
    10. void SSPIF_Handler()
    11. {
    12.     unsigned char  only_imp_bits;            // will store the status of relevant bits of the SSPSTAT
    13.     unsigned char  dummy;                    // place for dummy buffer read
    14.     char I2C_byte;                            // buffer contents will be stored in this
    15.
    16.     if(PIR1bits.SSPIF == 1)
    17.     {
    18.         only_imp_bits = SSPSTAT & 0b00101101;
    19.         switch(only_imp_bits)
    20.         {
    21.
    22.             case 0b00001001 :                 // state1:  D/A' = 0; S=1; R/W' =0; BF=1; Master Write Address
    23.                 // WRITE M->S last byte was an address
    24.                   I2C_DataIndex = 0;
    25.                 I2C_byte = SSPBUF;                    // dummy read to clear the 1-byte buffer
    26.                 break;
    27.
    28.             case 0b00101001 :                 // state2:  D/A' = 1; S=1; R/W' =0; BF=1; Master Write Data
    29.                 // WRITE M->S last byte was data
    30.                 I2C_byte = SSPBUF;            // read buffer and clear dirty flag
    31.                 if (I2C_DataIndex == 0)
    32.                 {
    33.                     I2C_DataIndex = &szDelayTime1[0];
    34.                     // we have a new virtual data pointer
    35.                     switch (I2C_byte)
    36.                     {
    37.                         case DEVICE_CODE:
    38.                             // virtual address == Timer Code
    39.                             I2C_DataIndex = &TimerType;
    40.                             break;
    41.                         case TIME_STRING1:
    42.                             // virtual address == TIME_STRING1
    43.                             I2C_DataIndex = &szDelayTime1[0];
    44.                             break;
    45.                         case TIME_STRING2:
    46.                             // virtual address == TIME_STRING2
    47.                             I2C_DataIndex = &szDelayTime2[0];
    48.                             break;
    49.                         case TIME_STRING3:
    50.                             // virtual address == TIME_STRING3
    51.                             I2C_DataIndex = &szDelayTime3[0];
    52.                             break;
    53.                         case VUTIL_STRING:
    54.                             // virtual address == VUTIL_STRING
    55.                             I2C_DataIndex = &szVUTIL[0];
    56.                             break;
    57.                         case ICC_STRING:
    58.                             // virtual address == ICC_STRING
    59.                             I2C_DataIndex = &szIcc[0];
    60.                             break;
    61.                         case SPIKE_COUNT:
    62.                             // virtual address == SPIKE_COUNT
    63.                             I2C_DataIndex = &SpikeCount;
    64.                             break;
    65.                         case FAIL_CODE:
    66.                             // virtual address == FAIL_CODE
    67.                             I2C_DataIndex = &FailCode;
    68.                             break;
    69.                         case I2C_MODE:
    70.                             // virtual address == I2C_State
    71.                             I2C_DataIndex = &I2C_State;
    72.                             break;
    73.                         case LED_GREEN:
    74.                             // virtual address == LED_GREEN
    75.                             // we don't use the data, just do the function
    76.                             SET_LED_GREEN;
    77.                             break;
    78.                         case LED_RED:
    79.                             // virtual address == LED_RED
    80.                             // we don't use the data, just do the function
    81.                             SET_LED_RED;
    82.                             break;
    83.                         case LED_OFF:
    84.                             // virtual address == LED_OFF
    85.                             // we don't use the data, just do the function
    86.                             SET_LED_OFF;
    87.                             break;
    88.                         default:
    89.                             // leave I2C_DataIndex as null
    90.                             break;
    91.                     }
    92.                 }
    93.                 else
    94.                 {
    95.                     // we have new data to write
    96.                     *I2C_DataIndex = I2C_byte;
    97.                     I2C_DataIndex++;
    98.                 }
    99.                 break;
    100.
    101.             case 0b00001101 :                 // state3:  D/A' = 0; S=1; R/W' =1; BF=1; Master READ Address
    102.                 // READ S->M last byte was address
    103.                 // load SSPBUF with first byte to send
    104.                 if (I2C_DataIndex != 0)
    105.                 {
    106.                     SSPBUF = *I2C_DataIndex;
    107.                     I2C_DataIndex++;
    108.                 }
    109.                 else
    110.                 {
    111.                     SSPBUF = 0;
    112.                 }
    113.                 break;
    114.
    115.             case 0b00101100 :                 /*state4:  D/A' = 1; S=1; R/W' =1; BF=0; Master READ Data*/
    116.                 // READ S->M last byte was data
    117.                 // load SSPBUF with next byte to send
    118.                 SSPBUF = *I2C_DataIndex;
    119.                 I2C_DataIndex++;
    120.                 break;
    121.
    122.             case 0b00101000 :                 /*state5:  D/A' = 1; S=1; R/W' =0; BF=0; Master Write NACK*/
    123.                 // master NACK'ed us...
    124.                 break;
    125.             default:
    126.                 I2C_byte = SSPBUF;                    // dummy read to clear the 1-byte buffer
    127.                 break;
    128.         }
    129.         SSPCON1bits.CKP = 1;        // release the SCL line if we're holding it down
    130.         PIR1bits.SSPIF = 0;            /*clear the SSPIF bit*/
    131.         if (SSPCON1bits.SSPOV == 1)
    132.         {
    133.             // we had an overflow
    134.             SSPCON1bits.SSPOV == 1;
    135.             I2C_byte = SSPBUF;            // read buffer and clear dirty flag
    136.         }
    137.     }
    138. }
    139.
    140. ///////////////////////////////////////////////////////////////////////////////
  3. dtrott
    Sep 29, 2011
    Hi ErnieM,
    Thanks for your reply.
    I've managed to get it working a bit more robustly with the removal of the:
    i2c_wait()
    routine out of the main function, which just put the program in a different loop until the SSPIF was set. I was able to remove all of the NOP's. But I don't know any more as to why it is so temperamental.
    Thanks again for reading and your code.
    Dan.
