Slave Clock
Discussion in 'General Electronics Chat' started by dhoneycutt, Mar 5, 2013.
  1. dhoneycutt
    Jan 1, 2011
    9
    I recently acquired a Digital Pyramid Slave wall clock and I do not know how to set or control the clock. I have found that the clock keeps time once it is started. Looks like it has 3-wire control (120vac, 24vdc, and common). Any ideas of a simple way to set the clock and/or control?
    Thank you,
    David
  2. shortbus
    Sep 30, 2009
    4,088
    1,670
  3. dhoneycutt
    Jan 1, 2011
    9
    Thanks for the info and link, but I just don't know what I am looking at. Can you give me a bit more info ??
  4. shortbus
    Sep 30, 2009
    4,088
    1,670
    The clock you have is called a slave clock. A slave clock (SC) has no time keeping ability, it is just a remote read-out of a master clock (MC). These systems are used in industrial or business settings, so all areas of the building are on the same time standard. And nobody can change the clock to suit their own agenda.
    The MC is the part you need, and it is usually pretty expensive to buy. It will have all the time keeping, SC control circuit and other things needed to use the SC's in the system. With out a MC the SC is pretty much useless. Except as a decoration.:)
  5. dhoneycutt
    Jan 1, 2011
    9
    When I power up the SC, it displays all zeros. I found that I could get the clock to start running and keeping time, but applying 110vac to the "110vac" input and common or I could apply 24vdc to the "24vdc" input and common. Each time I apply the input signal, the time advances to XX:58 and continues to run. I was able to set the clock by continuing to apply that input signal, wait for it to advance to the next hour, and then repeat the process. Took forever. There has got to be another way!
  6. shortbus
    Sep 30, 2009
    4,088
    1,670
    Yeah, that circuit I linked to.:)
  7. dhoneycutt
    Jan 1, 2011
    9
    Is the circuit that you posted likely the schematic for the Pyramid SC or a circuit to control the clock?
    Thanks!
