I was asked to repair a lantern with a sealed lead acid battery. It was not properly maintained and sat uncharged for a couple of years. It would not charge, so I opened it and found it to be bone dry. I refilled it, but it is obviously a victim of sulfation as it has virtually no capacity.
Clearly, I need to replace the original battery (SEL DMU 6-3) to salvage the lantern. Extensive searching proved an exact replacement is not available. The closest I've found is a Tempest TR2-6 (almost the same dimensions, but 2.3 AH vs. 3 AH). To compensate for the lower battery capacity, I was considering replacing the original 6V 3W Krypton bulb with a 40 lumen LED bulb (e.g., Dorcy 41-1664).
So, my questions are:
* Does replacing the Krypton bulb with an LED bulb sound feasible?
* The original charger appears to be a simple AC adapter (6V 100mA). Charging Lead Acid discusses the importance of 3-stage battery charging. Tempest does make a corresponding 3-stage charger for the TR2-6. Would it be a wise investment to purchase a 3-stage charger, rather than continue to use the original charger?
