Hello all,
I've got a question with regards to sketching Bode plots.
I'm supposed to sketch the bode plot of my transfer function,
\(T(s) = \frac{-390000 - 0.585s}{164368 + 0.019302s}\)
by hand.
EDIT: Whoops! I think I mixed my zeroes and poles up!
I should have a zero at,
\(\omega_{z} = \frac{390000}{0.585}\)
and one pole at,
\(\omega_{p} = \frac{164368}{0.019302}\)
When we compute these, it seems as though the zero occurs at a high frequency than the pole, so the bode plot would resemble a low pass filter, but when I modeled the circuit in Multisim it gives me a graph like the following,
I attached the original schematic of the circuit I'm working with as well incase someone can tell by inspection whether the circuit will act as a low, or high pass filter.
There is a possibility I may have made an error in my calculator computing the values of the transfer function, but I'd like to be sure before I redo all my calculations. (There's alot, and it's really messy)
EDIT: I just redid my calculations again and I arrive at the same result. Am I misunderstanding how to plot the bode plot correctly?
Now that I've got my zeros and poles sorted out, my plot should match this one!
What do you guys think?
by hand.
and one pole at,
