Sketch distribution of E from V
Discussion in 'Homework Help' started by mo2015mo, Jun 28, 2013.
  1. mo2015mo
    May 9, 2013
    157
    HI guys :) ,
    I have been having problem with the attached question, I just know this equation [​IMG]
    But I have no idea how I can sketch that?? :confused:
    Is there any way to solve It.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In 1 dimension you just take the derivative of the potential and change the sign.
    In 2 or more dimensions you need to add up the partial derivatives of the potential for each coordinate and then change the sign.
  3. circuitfella11
    Member
    May 10, 2013
    56
    5
    the equation you know means that E equals the change of V in two different points in time..e.g. from zero to 1, 1-2, 2-3, etc.. from there you can sketch distribution of E..
    ==hope this helps
  4. mo2015mo
    May 9, 2013
    157
    Papabravo & circuitfella11
    thanx u 4 your help
