Hello.
How do you size a coil for filtering the ripples at the output of a simple three-phase full-wave diode rectifier bridge, if the desired voltage is variable (0-48V, max 1000A)? And is it possible to use this, without a capacitor, given this situation?
A delta-wye transformer is used to power the rectifier.
Thanks.
Thanks.
