Size Counts!!
Discussion in 'The Projects Forum' started by JDR04, Oct 17, 2013.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    Hoping somebody can help with a small power supply circuit.
    I need to step 9Vdc down to 5Vdc for a microcontroller. Space is very restricted.
    Any suggestions will be appreciated. Thanks - JDR04
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
  3. wmodavis
    Oct 23, 2010
    737
    150
    A zener diode and a resistor?
  4. apqo1
    Oct 5, 2008
    50
    How much current? Consider:
    • Microcontroller overhead
    • Loss through pull-up/down resistors when outputs are low/high
    • Current sourced from micro's outputs
    • Other loads (sensors, motors, LEDs, etc.)
    Are you working with through-hole or SMD?
  5. BobTPH
    Jun 5, 2013
    807
    121
    78L05 in a TO92 case for up to 100mA.
    Bob
    #12 likes this.
  6. #12
    Nov 30, 2010
    16,704
    7,354
    Gotta go with, "There's nothing smaller than a TO-92 package". Even a 1/2 watt resistor and a zener have difficulties beating that.
    absf likes this.
  7. ErnieM
    Apr 24, 2011
    7,442
    1,628
    I did it several times with nothing more then a 2512 SMD resistor and a pair of 0805 caps, but that was cheating as the PIC has an internal regulator.
    Did it again using a pair of 0201 resistors, an 0201 cap and a very time transistor pair. Fit in perhaps .15 square and it was "wafer thin."
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If the O.P. can use SMD parts, you can get a lot of 5v linear regulators in the tiny SOT-23 package.
  9. #12
    Nov 30, 2010
    16,704
    7,354
    If only we knew how much power needs to be dissipated...
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yeah it would be great if people asking for help actually provided enough information. ;)
    But in the context of using it "for a microcontroller" we know a lot of micro projects only use a handful of mA. SOT-23 sized 5v regulators are common enough in 100mA-200mA capacity.
    #12 likes this.
  11. JDR04
    May 5, 2011
    339
    Thanks guys, going by some of the advice and questions asked,I need to do a bit more research so I can answer the questions raised.........
