Sites for information on transistors
Discussion in 'General Electronics Chat' started by SPQR, Jan 4, 2013.
  1. SPQR
    Nov 4, 2011
    379
    48
    Howdy,
    I'm going through a "transistor phase" trying to learn more about them and have found this site:
    www.alltransistors.com
    Do all of you use it?
    Or is/are there better site(s) for information on
    a - transistor substitution (finding "equal" transistors)
    b - general information about any transistor
    As usual, I thank you in advance.
  2. atferrari
    Jan 6, 2004
    2,666
    784
    Black background (plus those awful colors) is horrible. Hard to read for me. I do not even try.
    They seem to be all together but if you google any one, there are several sites also offering datasheets.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    On this site you will find links to all semiconductor manufacturers:
    http://sdw.bgs.nu/
    There are links to the homepages and data sheets.
    Bertus
    absf, spark8217 and PackratKing like this.
  4. ScottWang
    Aug 23, 2012
    4,930
    777
    Sometimes when you have to take a look at that kind of the sites, then you can moving your mouse into the range of the page, and press Ctrl+A on your keyboard, then it will change the color and looks better.
    When you want to recover the page then you just click the left button on that page, and it will return to the original color.
  5. ScottWang
    Aug 23, 2012
    4,930
    777
    I just found that site about one week ago, I didn't use it much, but I keep it in my database, I usually use http://www.datasheetcatalog.net/ to search the datasheets, when I can't find the datasheet of parts, then I will search on the other similar parts search engine, or search on google.
    absf and PackratKing like this.
  6. SPQR
    Nov 4, 2011
    379
    48
    Excellent input. Thanks.
    I'll add those sites to my "bag of tricks".
    PackratKing likes this.
  7. ScottWang
    Aug 23, 2012
    4,930
    777
  8. tshuck
    Oct 18, 2012
    3,531
    675
    absf and spark8217 like this.
  9. atferrari
    Jan 6, 2004
    2,666
    784
    Thanks for that tip, Scott.
    As you say, it works for some. Never heard of that trick. Where did you learn it?
    Gracias again.
  10. tracecom
    Apr 16, 2010
    3,879
    1,396
    Cntrl +A is simply "select all" in Windows.
  11. atferrari
    Jan 6, 2004
    2,666
    784
    Aha, so what I am using is kind of a "side effect" of that command. Nice. ;)
    If you say "select all" I immediately think of Ctrl E (as in Word which is the software I use more frequently at work).
    Thanks.
  12. SPQR
    Nov 4, 2011
    379
    48
    I thank you all.
    I've added all your suggestions to my "list".
    But you've also shown that the experts all have different approaches to the same problem.
    I just keep on lernin...
  13. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
