sir pls help me out with samsung sync master 753s monitor BY banty
Discussion in 'General Electronics Chat' started by bertus, Sep 12, 2011.
  1. bertus
    Thread Starter Administrator
    Apr 5, 2008
    15,806
    2,389
    I found this in my PM:
    As I do NOT answer PM's or e-mails, I have posted it here, so others can also give replies.
    Bertus
  2. iONic
    Nov 16, 2007
    1,422
    68
    Make sure all cables are securely fastened to both the monitor and computer. Try again.
    You may also see if you can try a different monitor with the same computer. They are not worth having someone fix it as it would cost as much as buying a new CRT style monitor.
  3. tom66
    May 9, 2009
    2,613
    214
    A *very* common fault with these Samsung SyncMasters (or as I like to call them, pieces of designed-to-fail junk) is the bunch of three 2-3W power resistors on one end of the power supply. All of them should measure 68 ohms, but often one goes open circuit. Replace the failed resistor with a 5W 68 ohm and your monitor should come back to life. Also check for bad capacitors. Good luck!
