Sip resistor for circuit
Discussion in 'The Projects Forum' started by nonsuchpro, Aug 25, 2013.
  1. nonsuchpro
    May 31, 2013
    15
    Hello all.
    I am currently working on this synthesizer project and am wondering (by looking at this schematic) if can I use SIP resistors for the 7 in series on each side. If so which type? A, B, C or D? Below is the schematic I'm working on and then the SIP types.
    Thanks in advance!
    Rob
    Type A - SIP
    Single row, isolated, individual resistors,
    each having two pins on the network.
    Total pin and resistor count given for each part.
    Type B - SIP
    Single row, ONE Common pin with
    all resistors bussed to remaining pins.
    Total pin and resistor count given for each part. ​
    Type C - DIP
    Dual row pins, isolated, individual resistors
    each with 2 adjacent pins, ie. 1-14, 2-13 etc.
    Type D - DIP
    Dual row pins, ONE Common pin with
  2. #12
    Nov 30, 2010
    16,704
    7,354
    Type A or C, if they can stand the amount of voltage (therefore power) you are asking them to survive.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    A (isolated SIP) or C (isolated DIP) if you connect them right but note that there are 8, not 7, resistors in the ladder on the right side of the schematic.
  4. nonsuchpro
    May 31, 2013
    15
    Awesome! I'm so glad I asked because I probably would have gone with B or D... heh.
    9-12v max is what I need. The SIPs just sounded like a good idea, but I've never worked with them before. It makes sense that they would accept less voltage.
    Good catch on the 8 resistors on the right KJ6EAD!
    Thanks a million guys!
    Rob
