Sinusoidal Signal Equation
Discussion in 'Math' started by Sparky49, Sep 19, 2011.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all,
    I've just got into another book on electronics, but I've come into a wee problem with the maths, in one part.
    Re. sinusoidal signals, I believe the equation to find the voltage is:
    V=Asin2∏ft
    That's fine with me. However, what I don;t quite understand is when you need to knwo the voltage at some arbitrary point in time, ie when t=0. The book says that the equation requires a phase in this equation:
    V=Asin(2∏ft+ϕ)
    What I don't understand is the need for the 2∏ft, as if t=0 then the whole bracket would come to θ!
    I'm clearly missing something here, could someone explain this to me please?
    The book is The Art of Electronics, by Horowitz and Hill.
    Thanks in advance,
    Sparky
  2. steveb
    Jul 3, 2008
    2,433
    469
    Well, you kind of have a good point here. Most often we really don't care about the (2 pi f t) part. It is quite common to use the "Phasor" representation of signals which considers the amplitude and the phase (phi or theta part). Usually, it's the relative phase difference between signals that matter and the angle (phi or theta) contains that information. The time t=0 is somewhat arbitrary anyway. You can define t=0 to be at any point.
    The use of the (2 pi f t) just provides a way to exactly specify the signal in time. There may be cases where you care about that information.
    Sparky49 likes this.
  3. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Your math is right, but your understanding may need help. You need to know the initial conditions (phase, θ) and the progression (2piFt) for the complete description of the system at any particular point in time.
  4. Sparky49
    Jul 16, 2011
    835
    417
    Thanks guys.
  5. samin
    Member
    Oct 14, 2011
    32
    6
    The sine wave can be understood as the projection onto the real axis of a rotating vector on the complex plane, so its argument is the total phase 2∏ft + θ, The phase constant θ represents the angle that the complex vector forms with the real axis at t = 0.
    Then based on the equation, you complete the description of the system:
    when t=0 ; t=T/4 ; t = T / 2 and so on.
