Sinusoidal PWM code for PIC18F452?
Discussion in 'Embedded Systems and Microcontrollers' started by Ahmed Waleed, Mar 10, 2009.
  1. Ahmed Waleed
    Mar 4, 2008
    22
    Dear All,
    Where can I find a code for sinusoidal PWM for PIC18F452 with frequency 60 Hz?
    and it must be all digital, no analog signals used (I mean i don't want to use ADC to compare sin wave with triangle wave) I want it fully digital, is it possible to find such a code?!
    if someone has done it, maybe it helps me so much.
    Thanks in advance
  2. mik3
    Feb 4, 2008
    4,846
    63
    Use the sin(x) function of a PIC and plug values of (x) with as much resolution you want to get sinusoidal digital values.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Or for a more pure pwm approach google <magic sine wave>
  4. Ahmed Waleed
    Mar 4, 2008
    22
    this is a very good calculation method, thnx
  5. Ahmed Waleed
    Mar 4, 2008
    22
    you mean I use an array using C and put the values of the sin function in it, or there is a possibility to make a function sin(x) and vary the variable X on whole the period (2∏).
  6. mik3
    Feb 4, 2008
    4,846
    63
    There a function sin(x) which calculates the sine value of any angle in radians.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    How do you get a variable duty cycle from that?
    John
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    I believe he was along these lines:
    Multiply sin(x) with 1/2 max resolution of PWM, add result to 1/2 max resolution. Use result for duty cycle.
    sin(180)=-1 - 0% duty cycle, sin (0) = 0 = 50% duty cycle, sin(90) =1 = 100% duty cycle. Change 0-360 degrees to 0-6.28 for radians.
    Put result through lowpass filter, followed by decoupling cap to center on zero.
