sinusoidal current source in SPICE?
Discussion in 'Homework Help' started by MattCarp, Mar 21, 2009.
  1. MattCarp
    Mar 21, 2009
    I was working on a drill problem and wanted to check my answer with SPICE, but I had a hard time determining what the SPICE code would be for a sinusoidal current source: 3 sin (2t - 60) (the "60" phase angle is in degrees and ω=2)
    Any ideas?
    Then for the analysis, I wouldn't have to sweep AC would I? Wouldn't this be sufficient:
    .AC LIN 1 0.3183 0.3183
    (of course, where freq = ω / 2 π = 0.3183 Hz)
    Thanks.
  2. MattCarp
    Mar 21, 2009
    ok,
    I was able to find a better manual online. Here's the syntax for a current source:
    I{name} {+node} {-node} [[DC] {value}] [AC {mag} [{phase}]]
    So, in my example, the source would be
    I1 1 2 AC 3 -60
    Then I'd need an analysis statement with the frequency!
    .AC LIN 1 0.318 0.318
    all better now!
