single transistor speaker amplifier
Discussion in 'The Projects Forum' started by Research Survey, Aug 21, 2016.
  1. Research Survey
    Feb 27, 2016
    14
    can you guys please help me build a simple transistor audio amp like the following
    https://bryanduxbury.com/2012/01/20/one-transistor-audio-amplifier-for-arduino-projects/
    or this
    http://www.next.gr/circuits/buzzer-interfacing-with-pic16f877a-slicker-l48286.html
    i try the following circuit but there is no output.
    my only available materials are
    bc 548b transistor
    4 ohm 0.5w speaker or d24mm Piezo Transducer
    i know i need to consult the datasheet to solve for the base collector emitter parameters but i dont know how.
    http://www.rectron.com/data_sheets/bc546-547-548.pdf
    my source is a frequency generator using 555timer ic with potentiometer varying the frequency
    pin output from ic is around 20 -25ma max
    my desired output is something like this
    hoping someone can teach me how to make one and how to compute one
    many thanks in advance.
  2. Colin55
    Member
    Aug 27, 2015
    204
    21
    Connect the 555 to the spkr via 10u
  3. Alec_t
    Sep 17, 2013
    5,956
    1,132
    As Colin says. A single transistor stage with a BC548B won't give you any more output volume.
  4. Colin55
    Member
    Aug 27, 2015
    204
    21
    It will give you LESS.
