Single supply opamps?
Discussion in 'General Electronics Chat' started by worldHello, Nov 11, 2014.
  1. worldHello
    Oct 15, 2014
    23
    Any suggestions on single supply op amps? I really really need those at the moment. I bought two different op amps ( I thought they are single supply based on my google search), and they are not single supply.
    suggestions please? Perhaps give me a website that sells it?
    Thank you,
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    You might want to read the attached PDF.
    Bertus
  3. crutschow
    Mar 14, 2008
    13,502
    3,376
    Note that there are single-supply amps that are not rail-rail input and output (the single supply amps generally only go to the negative rail). Do you need rail-rail operation?
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    What are your purpose, application, or schematic?
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    All op-amps are single supply. They don't care whether there is an arbitrary voltage reference in between the power rails.
  6. BobTPH
    Jun 5, 2013
    806
    121
    Wayne,
    That is my usual line. You won't believe the arguments you will get.
    The only difference between ordinary opamps, "single-supply" opamps, and rail-to-rail opamps is how close the inputs and outputs can be to the + and - rails.
    Bob
  7. wayneh
    Sep 9, 2010
    12,391
    3,246
    Exactly. IF there was a way to source and sink power to 3 rails, that might be a "dual" supply, but I've never seen such a thing. Certainly not a typical op-amp.
  8. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The opamps for everyone PDF has a table for single supply opamps on the end:
    Bertus
  9. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    Add to that; you need enough headroom to divide the supply into two halves and still exceed Vcc-min.
    If there's a spare op-amp left over in the package - some people use it up to buffer the voltage divider.
