Single supply op amp
Discussion in 'General Electronics Chat' started by sirch2, Feb 3, 2014.
  1. sirch2
    Jan 21, 2013
    1,008
    351
    I've never used a single supply Op Amp. Is there any reason I can't use a MCP6001 (datasheet - http://ww1.microchip.com/downloads/en/DeviceDoc/21733j.pdf) as a Schmitt trigger for a 40kHz signal?
    What I'm aiming to do is measure the phase difference between a transmitted and received ultrasonic signal. The output of the Schmitt trigger would be fed to a MCU which would time the difference between the two signals.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. ronv
    Nov 12, 2008
    3,404
    1,501
    It might be a little slow if you are trying to do what I think you are trying to do. A comparator with some hysteresis might be better.
  4. crutschow
    Mar 14, 2008
    13,526
    3,393
    At that frequency you definitely want to use a comparator as a Schmitt trigger, not an op amp which will give a slow response time.
  5. LvW
    Jun 13, 2013
    674
    100
    Yes - I agree with Crutschow, mainly because of the rather slow slew rate of the amplifier (only 0.6V/µs).
  6. t06afre
    May 11, 2009
    5,939
    1,222
    If you drive an opamp into saturation, it will need some time to get out of that saturation mode. That is one of reasons you really do not want to use a opamp as a comparator
  7. sirch2
    Jan 21, 2013
    1,008
    351
    Thanks for the replies. I'll do some research on comparators, I'm looking to ideally drive the whole thing at 3.3V but 5 to 6V could be an option, hence the reason I was looking at that Op Amp.
