Single Supply for TDA7294 ?
Discussion in 'General Electronics Chat' started by mmitaly, Feb 11, 2009.
  1. mmitaly
    Feb 6, 2009
    Will the TDA7294 Amp run off a single supply. Will referencing the minus input to 1/2 the supply voltage work?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Connect +Vs to your positive supply, -Vs to circuit ground, and reference the chip's inputs to a "virtual ground" half-way between.
    The datasheet mentions a minimum supply requirement. I suggest your positive supply be not less than 20V.
