Single pushbutton selector switch. Help needed.
Discussion in 'General Electronics Chat' started by evo.motorsport, Sep 3, 2007.
  1. evo.motorsport
    Jun 20, 2007
    21
    I’m trying to make single push-button selector switch. Every time button pushed output must switsh to the next output.
    It should work something like it indicated on this picture.
    or even better like on this picture.
    Please help
  2. Voltboy
    Jan 10, 2007
    197
    I guess that there are switches like this and that hardware stores maybe sells them. But if I had to do this on my own, I would use a pen, the type that you press to write, this pens work like this, they go up and down and move some degress around each time you push them.
    I think this could work for ya.
    -Yoda
  3. evo.motorsport
    Jun 20, 2007
    21
    I'm talking about digital solution, NOT mecanical.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A rotary switch would be pretty compact.
    As to the requirement - how many outputs? You have 4 pictured. Is the output to go high or low? What kind of load will the logic drive? Any logic family in mind? Does the output go back to zero after the highest count?
  5. evo.motorsport
    Jun 20, 2007
    21
    It has to be a push-button. Output must go to 1, 2, 3, 4 ,1, 2, 3, 4, 1, 2, 3, 4 and so on.
    I don't know what logic to use, that's why I'm asking you guys ;(
  6. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Check on the CD4017 cmos chip for the selector..... it can be configured for 1 to 10 sequentual digital outputs from a clock input..(or debounced switch).
    Check the CD4016 or CD4066 for the 4 x bilateral switch. These will switch analogue (audio works a treat) but can also be used for digital.
  7. evo.motorsport
    Jun 20, 2007
    21
    Thanks alot.
