Single Pushbutton On/Off
Discussion in 'The Projects Forum' started by Chris15, Apr 24, 2010.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    I have found a circuit here that i need some help reading as this is the first circuit i am attempting to make that is digital.
    http://www.discovercircuits.com/H-Corner/on-off-switch.htm
    Just with the IC Thing in the middle i am having trouble on how to read it i counted it like an IC but wanted confermation
    Also can i make it operate off 3V, as it is easier and 2.6 is harder to achieve, or does anyone know this same circuit but in a simpler form
    Thanks Chris
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    From the text associated with the circuit -
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Pin layout? 1-5 anticlockwise looking from the top.
  4. VoodooMojo
    Nov 28, 2009
    503
    53
    http://www.egr.msu.edu/classes/ece480/goodman/read_datasheet.pdf
    Chris,
    a good habit to get in to is to download datasheets for all the unfamiliar components in a circuit you are building.
    After studying them a few times, they actually start to make a bit of sense.
    here are three from your schematic.
