I hope this explains everything clearly. Switches can be anything. either High and Low (debounced), or push button to ground.No. The UP pin must be HIGH if you want to count down. The DOWN pin must be HIGH if you want to count up. Whichever way you are counting, the other pin must be HIGH, as stated on the datasheet.
This will go a lot faster if you post your current circuit schematic including wiring to external switches.
ak
side question: since I only have few 104 and 103 Capacitors left. is it ok to use the equivalent Polarized Capacitor?those aren't very clear to me.
