Yes it is possible, in fact you could have many more than two inputs and outputs, so long as you want the same division ratio for each inputs.Is there any possible way to have two inputs go to the same pot, and then two seperate outputs, without mixing them? or would I need to get two seperate pots to do this?
by Jake Hertz
by Jake Hertz
by Jake Hertz
